Data popularization in table
  • Aug 4, 2015 4:52 AM UTC
  • 6 replies
  • 63 views
Hi for all!
I have  xls table with huge datas about inspection for different zones as shown in attached picture (this is the small example).
How can I write text values from "Area n." column to "Area"?
F.e. for rows with "Area n" 1, 12, 3 I want write East gate in "Area" column and etc.
Thx
Best answer by takashi
This is a solution example based on Gio's suggestion - VariableSetter/VariableRetriever.
  • Aug 4, 2015 8:08 AM UTC
  • Aug 4, 2015 9:13 AM UTC
I'm not sure how the table should be transformed.
Do you need to add the area name to the "Area" column like this?
Takashi
gio
Forum|alt.badge.img+15
  • Aug 4, 2015 2:05 PM UTC
You can achieve this by reading the column "Area n." into a variable for each occasion the value is not a number.
You parralely (..is that a good word??) read the variable (using a VariableFetcher) into Area attribute.
Or you can simply use a conditional attribute creator with adjacent feature reading. (though with big data this will use more memory,( i have scripts that crash on memoryusage when using adjacent featuresettings)
  • Aug 5, 2015 1:01 AM UTC
Takashi,
Yes, It should looks like on your picture...
  • Aug 5, 2015 2:51 AM UTC
  • Aug 5, 2015 6:30 AM UTC
Gio, Takashi!
Many Thanks!
