CSV to Point Cloud
  • January 7, 2014
  • 5 replies
  • 183 views
I am trying to convert a CSV file (no header, just X Y and Z columns) into either a LAS or POD file format.  However I keep getting the error:
"Failed to obtain point cloud from feature.  Only features with point cloud geometry are expected"
Is there a step that I'm missing here?
Thanks,
fmelizard
Forum|alt.badge.img+17
  • January 7, 2014
Most probably, can you describe what you are doing?
Tip add the header in the CSV and save as .xyz file.
Itay
  • January 7, 2014
Hi Itay
There is no header in the CSV....
when you say Save as .xyz is this within FME or outside of FME?
All I have in my FME workbench at the moment is a CSV reader and an LAS writer.  I tried to put the "3DPointReplacer" transformer in between them, but I got the same error..
Thanks,
  • January 7, 2014
have you tried passing your points through a GeometryCoercer set to "fme_point_cloud" before the Writer?
David
fmelizard
  • January 7, 2014
Outside FME open the CSV and add the header (XYZ), and save as myfile.xyz
This way you can use the XYZ reader (much faster than the CSV) and FME recognizes it as point cloud geometry.
Itay
  • January 7, 2014
Thanks Itay and David,
I used the POINTCLOUDXYZ reader and changed the delimiter to a comma and it worked successfully.
