CSV Reader - Option: "File Has Field Names: yes"
  • Mar 17, 2014 3:48 PM UTC
  • 7 replies
  • 124 views
Hello,
my problem is to read a CSV file without field names. You can find the images mentioned in the error description in the folder "Screenshots" .
It read and process the file " Importbeispiel_100_Adressen.csv " successfully. I use the parameters as shown in the screenshots "csv_parameter_1.jpg" and  "promt_and_run_1.jpg". The expected result ("_target_url") is correct:
"http://fvs72.lgb.local/gdigeokoder/RestService/GeokodiereAdresse?key=zgnsjf&str=Milmersdorfer%20Chaussee&hn=25&hne=&plz=17268&ort=Ahrensdorf&ot=&srs=EPSG:25833"
If I want to read the file "Importbeispiel_100_Adressen_oue.csv" (see "promt_and_run_2.jpg") it does not work. The "_target_url" can not be properly generated:
"http://fvs72.lgb.local/gdigeokoder/RestService/GeokodiereAdresse?key=zgnsjf&str=&hn=&hne=&plz=&ort=&ot=&srs=EPSG:25833"
I suspect the problem lies here (see log): "CSV Reader : File Has Field Names : yes". As can be seen in the file "csv_parameter_1.jpg", I have the option disabled. Nevertheless, they will call for both activated. Furthermore, thereby also skipped the first line.
Here is the workbench and screenshots:
https://www.dropbox.com/s/qg2vr92v03vdod1/Massengeokodierung_REST_FME.zip
Version:
Edition: FME Desktop ESRI Edition (floating)
Version: FME(R) 2013 SP3 (20130729 - Build 13528 - WIN32)
Thank you for your efforts!
  • Mar 19, 2014 10:25 AM UTC
you might have better luck using the Python CSV module if your CSV data is a bit complex or contains special characters. I have posted a working example of how to do this here (http://fmepedia.safe.com/CommunityAnswers?id=906a0000000ckLRAAY).
David
gio
Forum|alt.badge.img+15
  • Mar 19, 2014 10:32 AM UTC
hi,
It skips the firstline because u have lines to skip 1 Header set to to yes.
One input file has a header the other not, so it seems logical not to use same settings on both.
When u make a custom transformer, the settings prompted override the ones in the navigator i think.
So even if you have "number of lines to skip" 0 (linked to skip-lines_csv) in the navigator, the screenshot in your csv_parameter_1.jpg shows its goin to skip a header (prompted).
Look at a part of a workbench i made. Look at the "promptscreen" and the settings in the Navigator. The ones in the prompt Override.
Gio
  • Mar 20, 2014 3:58 PM UTC
HI,
@Gio:
I thing the problem is in the option "File Has Field Names". This is always set to "yes". No matter what I have previously defined. This will also set "Number of Lines to Skip = 1", although I have said in the query at the start, "Number of Lines to Skip = 0".
You can see it in the logs:
a) "Number of Lines to Skip = 0", CSV without header
CSV Reader: Separator Character: ';'
CSV Reader: Skip Duplicate Delimiters: no
CSV Reader: Strip Quotes From Fields: yes
CSV Reader: File Has Field Names: yes
CSV Reader: Field Names Follow Header: no
CSV Reader: Number of Lines to Skip: 1
CSV Reader: Number of Footer Lines to Skip: 0
CSV Reader: Allowing Spaces in Column Names: yes
CSV Reader: Max features to scan for schema: 10000
CSV Reader: A column name of 'col2' was used to replace a blank column name
CSV Reader: Opening dataset 'C:\\Users\\ulbrichg\\Desktop\\Massengeokodierung_REST_FME\\Input\\Importbeispiel_100_Adressen_oue.csv'
b) "Number of Lines to Skip = 1", CSV with Header
CSV Reader: Opening dataset 'C:\\Users\\ulbrichg\\Desktop\\Massengeokodierung_REST_FME\\Input\\Importbeispiel_100_Adressen.csv'
Please give can you give me the link to your Workbench?
Thanks!
@David:
That will probably be the solution for my problem. With your pattern it will work.
I'll let you know if it worked. Thanks!
Georg
  • Mar 20, 2014 4:00 PM UTC
you might also want to try and upgrade to FME 2013 SP4 to see if this issue has been resolved there.
David
  • Mar 20, 2014 4:09 PM UTC
Hi David,
i have tested it already with:
Version: FME(R) 2014 (20140120 - Build 14235 - WIN32)
The problem is the same. But in 2014 i can't find this menu
https://www.dropbox.com/s/flu080r4kw41ov1/csv_parameter_1.jpg
Georg
  • Mar 20, 2014 4:16 PM UTC
David, can you please show me as a template a workbench in which you use your own CSV reader with the Python Creator?
  • Mar 31, 2014 11:57 AM UTC
I could solve my problem. I'm not sure what it was. However, I re-added to the CSV reader and set the option "Merge Feature Type".
Thanks for the replys!
