CSv file
  • Jan 14, 2018 12:45 PM UTC
  • 9 replies
  • 106 views
I have A csv file with more 10000000 records how can split into 5 smaller csv file (each with + o- 2000000 refcords) to performafter my actions ?
danilo_fme
Forum|alt.badge.img+58
  • Jan 14, 2018 6:58 PM UTC
Hi @frsisani,
1 - After your Reader you can use the transformer StatisticsCalculator to have a count of features in Attribute = number.
2 - Use the transformer ExpressionEvaluator to calculate @Value(number)/5 and generate the attribute group.
3 - Use the transformer Count to generate the attribute _count and after another transformer ExpressionEvaluator = result
int(@Value(number/@Value(group))
4 - Connect the output port ExpressionEvaluator in your Write file and set the configuration CSV File Name = _result
5 - Set in Navigator the Option Fanout.
Attached the Workspace. - workspace-fanout-split.fmw
Thanks,
Danilo
mark2atsafe
Forum|alt.badge.img+59
Alternatively a Counter/AttributeRangeFilter combination might be useful.
I also note a Grouper transformer on the FME Hub, although I haven't tried it myself.
jdh
Forum|alt.badge.img+41
  • Jan 15, 2018 9:14 PM UTC
If the order of the records is irrelevant, I would use a ModuloCounter (set to 5), and fanout based on the _modulo_count. That way the features aren't being kept in memory to determine the total number of features (StatisticsCalculator).
  • Jan 16, 2018 1:51 PM UTC
Hi @frsisani,
Thanks,
Danilo
I suspect using a blocking transformer on 10 million features isn't going to be super fast...
  • Jan 16, 2018 1:53 PM UTC
The Grouper: Non-blocking and doesn't mess up the record order, I like it!
  • Jan 16, 2018 2:48 PM UTC
I would just use a feature type fanout expression like this.
output_@Evaluate(@int(@Count()/2000000))
mark2atsafe
Of course. ModuloCounter is a great solution here.
jdh
  • Jan 16, 2018 3:36 PM UTC
Yeah, I had considered that, but it presupposed the total number of records.
  • Jan 16, 2018 4:01 PM UTC
If the number of files must be five even if the number of input records was more than 10 million, this expression is available.
