CSV: failed to open error
  • Jan 20, 2020 6:21 PM UTC
  • 163 views
fpakzat
Forum|alt.badge.img+3
The file path was working fine on Workbench but it's giving me this error when I put the FME script in Task Scheduler (or Command Line).
robotix
Forum|alt.badge.img+10
  • Jan 20, 2020 6:32 PM UTC
@fpakzat Would need to see more of the error and/or your syntax for the script. It can fail for many reasons.
fmelizard
Forum|alt.badge.img+22
Hi @fpakzat The system user might not have access to that file path. See https://knowledge.safe.com/questions/3881/fme-workbench-on-windows-scheduler.html and https://knowledge.safe.com/questions/67628/fme-batch-file-works-but-not-via-windows-task-sche.html for ideas of how to work around the Windows Task Scheduler.
robotix
  • Jan 20, 2020 6:46 PM UTC
@fpakzat drop another line here of those links from danstasafe don't help. I use task scheduler, flat files and call fmw with .bat scripts on a regular basis. Maybe i can help.
fpakzat
  • Feb 6, 2020 7:42 PM UTC
I think I found the reason. I got away with this problem by using the path follows UNC standard. I didn't realize the previous path that I used contains a Mapped Drive.
\\servername\path
