CSmap Reprojector unable to load Geoid Height Grid
  • Jun 26, 2025 7:58 AM UTC
  • 145 views
ischu
Hi All,
I am trying to reproject a .tif file with the xy coordinate system NAD_1983_UTM_Zone_16N
to WGS84 and vertical coordinate sytem EGM08.
I downloaded the aditional .grd files from FME and saved them under
C:\Program Files\FME_2022_1\Reproject\EsriPEGridData\vertical\egm\egm2008-1.grd
I created a .gcs file which is located under C:\Program Files\FME_2022_1\Reproject\GeoidHeightGrids\World\egm2008_1.gdc and looks like this: ..\..\EsriPEGridData\vertical\egm\egm2008_1.grd
I always get the following error message: CsmapReprojector (TeeFactory): CsmapReprojector: Reproject: Could not reproject the geometry of the preceding feature: CS-MAP Reprojector: Unable to load geoid height grid 'C:\Program Files\FME_2022_1\Reproject\GeoidHeightGrids\World\egm2008_1.gdc'
What am I doing wrong?
Any help very much appreciated.
itsmatt
Forum|alt.badge.img+48
  • Jul 1, 2025 8:35 AM UTC
Are you able to try the ESRIReprojector at all? Looking at the name of the grid I wonder if the ESRIReprojector might be better suited here.
