Creating polygon from API response
  • Jan 31, 2020 11:55 AM UTC
  • 118 views
mattebridges
Forum|alt.badge.img+8
Hello - I'm trying to create a polygon from co-ordinates received from an API call. The response body containing the co-ordinates is attached. The response can include shells and holes and I would like to be able to create both of these features if required (the attached example doesn't include shells but we will encounter these in future use).
I think the response form the API is JSON and the workbench I've built to call the API is storing this response in an attribute ('_response_body').
I'm really not sure how I can turn these co-ordinates into a polygon and I would be so grateful for any help.
Thanks in advance and all the best,
Matt
jdh
Forum|alt.badge.img+41
  • Jan 31, 2020 3:54 PM UTC
jsonpolygon.fmwUnfortunately that response is not a standard geoJSON or esriJSON, so you can't just use the geometryReplacer to create the polygon.
There are two ways to approach this, either convert the response to a standard geoJSON or extract the coordinates and rebuild the polygons.
The second approach is perhaps less efficient, but is far easier to understand.
A series of JSONFragmenters, or a recursive JSONFragmenter and some listExploders to get one feature per vertex with a common id.
VertexCreator, LineBuilder, DonutBuilder with the latter two grouped by common id to get the geometry.
mattebridges
  • Jan 31, 2020 5:32 PM UTC
@jdh - thank you so much for this - with some minor amendments it's working perfectly. I am VERY grateful.
