Creating Empty File Geodatabase
Is it possible in FME to create empty Esri file geodatabases without any feature classes inside? Like how you would manually create them in ArcCatalog.
Best answer by rahulsharma
Hi @jm_spatial, currently this is not possible with FME Desktop as Writer will always require a FeatureType.
You can create an empty folder with name.gdb using a FileCopy or a simple python script
rahulsharma
Forum|alt.badge.img+10
  • April 2, 2020
Hi @rahulsharma, thanks for that. It would have been handy in implementing automation.
I know how to create file gdb using using python so I guess that would have to do for now.
bwn
Forum|alt.badge.img+26
  • April 3, 2020
It is possible, but they aren't particularly elegant. If you're comfortable just calling it from the ArcPy library then PythonCaller will likely do it inside FME.
Import arcpy
arcpy.CreateFileGDB_management(out_folder_path, out_name, {out_version})
