Creating a postgresql function in fme - ERROR: unterminated dollar-quoted string at or near "$BODY$"
  • Mar 12, 2018 2:40 PM UTC
  • 1048 views
Dear all
I am trying to compose a PostgreSQL function in FME using the SQLExecutor. My function installs correctly within pg admin, but since there is a dollar($) symbol included in the query, my function won't install correctly via FME and I receive the following error:
Error executing SQL command ('CREATE OR REPLACE FUNCTION gv.create_tables_from_foreign_schema(_foreign_schema character varying, _local_schema character varying)
  RETURNS void AS
$BODY$'): 'ERROR:  unterminated dollar-quoted string at or near "$BODY$"
The function looks like this:
CREATE OR REPLACE FUNCTION $(p4_p3_schema).create_tables_from_foreign_schema(_foreign_schema character varying, _local_schema character varying)
  RETURNS void AS
$BODY$;
declare
    selectrow record;
begin
for selectrow in
select 'CREATE TABLE ' || quote_ident(_local_schema) || '.' ||quote_ident(t.table_name) || ' AS SELECT * FROM ' || quote_ident(_foreign_schema) || '.' ||quote_ident(t.table_name) || '' AS qry
from (
     SELECT table_name
     FROM information_schema.tables
     WHERE table_schema = _foreign_schema
     )t
loop
execute selectrow.qry;
end loop;
end;
$BODY$;
  LANGUAGE plpgsql ;
Has any of you experience either creating functions or triggers, from within FME using the SQLExcecutor and have you been able to circumvent this problem of using "$"? It's obvious that the $ symbol is reserved for FME parameters, so I wonder if either I could alter that  FME setting or rewriting my SQL query?
  • Mar 12, 2018 3:22 PM UTC
I assume that the workspace contains a private or published parameter called "p4_p3_schema", is that right?
Using that assumption, I was able to make it work by removing the semicolon after the two $BODY$-statements, e.g.
  RETURNS void AS
$BODY$
declare
    selectrow record;
begin
for selectrow in
from (
     SELECT table_name
     )t
loop
end loop;
end;
$BODY$
LANGUAGE plpgsql ;
Tested with FME  2017.1.2.1
  • Mar 13, 2018 9:12 AM UTC
  RETURNS void AS
$BODY$
declare
    selectrow record;
begin
for selectrow in
from (
     SELECT table_name
     )t
loop
end loop;
end;
$BODY$
LANGUAGE plpgsql ;
Hej david_r. You are right about the parameters. Initially, i did not have the semicolon after $BODY$ , but I guess that in my attempt to make it work, tried it out and it came in the code that I posted here. Now, I did make workbench work when I spread my SQL query across multiple SQLExecutors. I don't know why, but it seems that having multiple SQL database commands within one SQL executor might be a bit too much for FME to handle, so a stepwise procedure with multiple SQLExecutors, works in my experience well. At the end of my workbench I now only have an SQLExecutor that execute my function caller.
