create relationships between tables in an access writer
  • Sep 14, 2018 2:44 PM UTC
  • 126 views
gboquin
Forum|alt.badge.img+8
Good morning FME'rs
Does anybody know about a clever way to create relationships between tables while writing to an access database?
Best answer by david_r
You can use the SQLExecutor and some SQL to alter the table definition with relationships:
https://docs.microsoft.com/en-us/office/vba/access/concepts/structured-query-language/define-relationships-between-tables-using-access-sql
  • Sep 14, 2018 3:00 PM UTC
gboquin
  • Sep 14, 2018 3:08 PM UTC
Thanks, Dave: I was looking into that but ran into an error. I was trying to execute the SQL after translation...
See syntax below:
Alter table [MH_Inspections] add constraint FK_MH_Inspecitons_Media Foreign key ([InspectionID]) references [MH_Inspections_Media] ([InspectionID]); Error:
Creating reader for format: Microsoft Access (JDBC)
Trying to find a JAVA plugin for reader named `MSACCESS_JDBC'
Using Java Reader Interface Version 2.0 (Oct 31, 2000) with module MSACCESS_JDBC to read data
MS Access (JDBC) Reader: Preloading JDBC Driver Class 'net.ucanaccess.jdbc.UcanaccessDriver'
MS Access (JDBC) Reader: Creating connection using connection string 'jdbc:ucanaccess://F:\\\\TestDatasets\\Test3.mdb' and properties '{jackcessOpener=COM.safe.fme.jdbc.msaccess.MsAccessCryptCodecOpener, immediatelyReleaseResources=true}'
MS Access (JDBC) Reader: Connected to 'UCanAccess driver for Microsoft Access databases using HSQLDB' version 'V2010 [VERSION_14]' using driver 'Ucanaccess' version '4.0.2' built against JDBC version '4.0'
MS Access (JDBC) Reader: Connection class 'net.ucanaccess.jdbc.UcanaccessConnection' is being loaded from '/C:/Program Files (x86)/FME/plugins/ucanaccess-4.0.2.jar'
MS Access (JDBC) Reader: Executing SQL: Alter table [MH_Inspections]
net.ucanaccess.jdbc.UcanaccessSQLException: UCAExc:::4.0.2 a UNIQUE constraint does not exist on referenced columns: MH_INSPECTIONS_MEDIA in statement [Alter table MH_INSPECTIONS
add constraint FK_MH_Inspecitons_Media Foreign key ( INSPECTIONID ) references MH_INSPECTIONS_MEDIA ( INSPECTIONID )]
  • Sep 14, 2018 3:12 PM UTC
See syntax below:
At first look, my guess is that the column MH_INSPECTIONS_MEDIA.INSPECTIONID hasn't been declared as unique.
gboquin
  • Sep 14, 2018 3:34 PM UTC
Thanks for the tip-- I had the relationship done backwards in the syntax. I am testing replacing the access writer with a feature writer and passing it to the SQL Executer transformer.. it seemed to work on the first test-- just a couple of tables. I just don't get it why it would not work with the "SQL to Run after Write" under advanced parameters.
