Create polygons from a string of coordinates
  • Sep 30, 2024 2:00 PM UTC
  • 6 replies
  • 276 views
ricardoa
Forum|alt.badge.img+3
Hi there!
I want to create polygons from an attribute that contains a string of coordinates and other information.
My problem is that I don't know how to only extract the coordinates from the string and then create the polygons by their ID attribute.
The string in the coordinates attribute looks like this:
“{"type":"Feature","properties":{},"geometry":{"type":"Polygon","coordinates":[[[13.707920553133594,60.03475791657763],[13.708950521395312,60.03304306231432],[13.705474378512012,60.03160680337132],[13.702513219759567,60.02997753853561],[13.702255727694139,60.030577803349054],[13.703929426119434,60.03184261136259],[13.706161024019824,60.032571461785544],[13.707920553133594,60.03475791657763]]]}}”
ID attribute 1 to 10
Regards,
Ricardo :)
Best answer by nielsgerrits
Thank you @nielsgerrits !!!
Here is the file.
Workspace sample attached.
nielsgerrits
Forum|alt.badge.img+67
You can create a geometry from this using the GeometryReplacer. Set it to Esri JSON. If that does not work you might need to extract the geometry part using the JSONExtractor. If you want me to create a sample workspace, you’ll need to attach complete source file.
ricardoa
  • Oct 1, 2024 5:28 AM UTC
Here is the file.
nielsgerrits
Here is the file.
ricardoa
  • Oct 2, 2024 5:07 AM UTC
Thank you @nielsgerrits 😃👍🏽😄
thomasmarti
Forum|alt.badge.img+9
  • Oct 7, 2024 7:22 PM UTC
Hi @nielsgerrits
why did you use the FeatureReader instead of the Excel-Reader? What are the benefits of your solution?
Greets
Tom
nielsgerrits
Hi @nielsgerrits
Greets
Tom
Hej Tom, this is personal preference. When the FeatureReader and FeatureWriter were introduced (in 2016?) I stopped using the classic Readers and Writers. I find them more intuitive to configure. All our teammembers use FME this way.
