Create polygon feature from CSV
  • Dec 18, 2017 2:49 PM UTC
  • 207 views
kumarkannan1980
Participant
I have set of coordinates for a polygon in CSV format, I need to create the polygon from the coordinate in FME. Kindly let me know which transformer I have to use.
Regards
K.Jayakumar
erik_jan
Forum|alt.badge.img+26
  • Dec 18, 2017 2:56 PM UTC
Have a look at the GeometryReplacer transformer.
If you can format the coordinates (usually as WKT) you can create the polygon using that transformer.
  • Dec 18, 2017 2:57 PM UTC
Here's one way, assuming you have an attribute containing the polygon ID and the CSV has the polygon vertices in the correct order:
  1. VertexCreator to convert X,Y values to point geometry
  2. LineBuilder, connection break attribute = your polygon ID
  3. LineCloser, only necessary if the polygons don't close completely
  4. GeometryCoercer set to "fme_polygon" (alternatively look at the AreaBuilder if you have donuts etc)
If you need more specific instructions, consider posting a small sample CSV dataset.
  • Dec 18, 2017 2:58 PM UTC
Depending on the actual schema of the CSV. If you could post a sample data, it would help us to think of a suitable way.
kumarkannan1980
Participant
Thanks it is working
