Create parameter for WHERE clause
  • Nov 29, 2021 2:32 PM UTC
  • 65 views
rtreecare
I have two arcgis online feature layers (jobsites and trees) that are in a 1:M relationship. On the trees reader, I've set where clause as "EditDate" >= CURRENT_TIMESTAMP() - 7.
The resulting features in this reader have the globalid attribute found in the jobsites layer. I would like to read just jobsites with globalids found in the trees reader. How do I create a dynamic where clause for the jobsites useing a unique list of globalids from the trees layer?
So far I've used Listbuilder, DuplicateFilter, ListConcatenator, and StringReplacer to get a list of unique globalid's -
'{28F268A5-7390-4FFC-9EF6-C522D1237ECE}','{28F268A5-7390-4FFC-9EF6-C522D1237ECE}','{28F268A5-7390-4FFC-9EF6-C522D1237ECE}','{28F268A5-7390-4FFC-9EF6-C522D1237ECE}','{28F268A5-7390-4FFC-9EF6-C522D1237ECE}','{28F268A5-7390-4FFC-9EF6-C522D1237ECE}'
The first issue is how do I make the string say the following:
GlobalID IN ('{28F268A5-7390-4FFC-9EF6-C522D1237ECE}','{28F268A5-7390-4FFC-9EF6-C522D1237ECE}','{28F268A5-7390-4FFC-9EF6-C522D1237ECE}','{28F268A5-7390-4FFC-9EF6-C522D1237ECE}','{28F268A5-7390-4FFC-9EF6-C522D1237ECE}','{28F268A5-7390-4FFC-9EF6-C522D1237ECE}')
The second issue is how do make that where statement a paramenter for the jobsite reader?
Thanks!
nielsgerrits
Forum|alt.badge.img+67
If I understand you want to chain two FeatureReaders together. This way you can read the jobsite you want, then all trees with that jobsite id?
rtreecare
  • Nov 29, 2021 4:16 PM UTC
That sounds pretty close except I want all jobsites with jobsiteIDs that are found in the tree FeatureReader.
ctredinnick
Forum|alt.badge.img+22
  • Nov 30, 2021 9:26 AM UTC
Assuming the output of your ListConcatenator/StringReplacer is an attribute named jobsitelist, then I think you can just pass that into a FeatureReader, reading from the jobsites layer where GlobalID IN (@Value(jobsitelist))
