Create new features
  • Feb 21, 2020 4:38 PM UTC
  • 201 views
I am looking to insert a new feature into the output geodatabase here. The translations uses a feature reader to read a source geodatabase based on a user defined parameter which defines which feature classes the user wants to bring over. However I also need to add second feature class but instead of reading from a source I need to add a new record which i intialize from the creator. In this case though because the output writer uses a dynamic schema, I don't know how to insert this new feature or to indicate which feature class it should be written to. Any ideas?
@slangley You should be able to have both a 'regular' feature type and dynamic feature type attached to the same writer. Writers menu use Add Feature Type or Import Feature Type.
