Create geodata, feature classes, domain value from excel file
  • Jul 1, 2024 12:40 PM UTC
  • 106 views
claireco
Good evening
I produce a worbench wich create a file gdb and different features class (table, polyligne, polygon) from a excel file wich describe :
  • fme_feature_type_name
  • fme_feature_type_alias
  • name
  • alias
  • fme_data_type
  • geometry
  • native_data_type
Is it possible in the same excel file  :
  • to create domain value (domain code and domain describe)
  • to apply Global Id
  • to apply editor trackor
    Thank you
hkingsbury
Forum|alt.badge.img+73
  • Jul 1, 2024 8:07 PM UTC
I’m assuming this is for an esri enterprise environment? You’ll have to use python for those steps.
For domains, have a look here:
It says GDB in the title, but is also applicable to SDE
GlobalIDs:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/add-global-ids.htm#GUID-DAFED90C-5514-48C3-926C-989D7DF1466E
Editor Tracking:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/enable-editor-tracking.htm#GUID-5FC43A7F-A6B5-491E-A188-054EB618E24F
