create an empty polygon and verify is it an empty polygon or not
  • January 22, 2019
  • 6 replies
  • 94 views
i had 2 question ,
1, how to create an empty polygon (i v tried with creator function but with no result)
2, how to verify if a polygon had an entity or is empty ?
Forum|alt.badge.img+62
You can create a feature with a NULL geometry using the Creator, is that what you mean? And for checking what kind of geometry a feature has you can use the GeometryFilter, have it check for NULL.
hi, thanks for your answer , so what i need, is to place a terminator when a feature has no entity, so i v tried whith counter, but, when i test a file with no entity the counter doesnt had an input.
What exactly do you mean with "no entity"?
it means that a feature had no rows .
itay
Forum|alt.badge.img+18
  • January 23, 2019
You can create a polygon using the Creator not very handy if its a complex polygon with many coordinates, since you have to manually insert the XY values.
An easier way with the creator to create a simple box polygon is Geometry Object: 2D Min/Max Box, just be aware it expects space separated values (e.g. 0 0 10 10)
If you erase the Creation Instance Attribute value, you get a polygon with no attributes.
virtualcitymatt
Forum|alt.badge.img+47
Perhaps you are after the NoFeatureTester (custom transformer) connect that up to your polygon input. If there are features they will come out the output, if there are none then a feature will come out of the NoFeatures Port. You can place a Terminator on that port to halt the process.
Super handy tool
