Create a primary integer autoincrement key in sqlite
  • May 9, 2023 10:55 PM UTC
  • 332 views
kimo
Forum|alt.badge.img+10
I can set an index on an integer or even a unique index, but there is no type for a primary key or autoincrement. How can I specify this? I could do this with an SQL Create expression. Can I use SQL to create a schema?
I am adding a changeset with new records using insert but I need an OID column for ArcGIS to be able to use the table/featureclass separate from the real ID.
kimo
  • May 10, 2023 12:33 AM UTC
My workaround is to post process use the 'SQL to Run After Write' :
UPDATE changeset SET OID = rowid where OID is NULL
Not quite a proper autoincrement, but it gets around the current roadblock.
nielsgerrits
Forum|alt.badge.img+67
I think this can be dine in the User Attributes tab in the (Feature)Writer. Set type to integer and Index to Unique.
2023-05-10_13h07_22
