Correct WHERE Clause for Geodatabase Reader
  • Apr 8, 2014 8:25 PM UTC
  • 5 replies
  • 560 views
I'm attempting to limit the number of records being read on multiple file geodatabases by setting the WHERE Clause parameter to yesterday's date:
Edit_date BETWEEN SUBDATE(CURDATE(),1) AND CURDATE()
"Edit Date" is Field Name and the Data type is Date.  I've tested a few different SQL statements, but can't seem to get the right combination? Is this the right approach or is there a better way?
Gary
  • Apr 10, 2014 7:37 AM UTC
this is more of an ArcGIS questions than an FME one, as FME transmits the WHERE-clause directly to the underlying database, which is then responsible for parsing it.
Perhaps try the ESRI forums, if nobody here has a suggestion.
David
  • Apr 10, 2014 10:02 PM UTC
David,
Thanks for pointing me in the right direction.  I now have another question.  Can you pass the a value from a startup python script (function) into the parameter of a reader?  In other words I want a reader parameter that looks for Yesterday's date and only reads records that where changed the previous day.  I have a python function that sets the correct SQL format:
def Yesterdays_Date():
import datetime, time
today = datetime.date.today()
day = datetime.timedelta(days=1)
yesterday = today - day
date_format = yesterday.strftime("%Y-%m-%d")
datestring = "Edit_date = date ' " + date_format + "'"
return(datestring)
I just need to get it into the Reader's Where Clause.  Does substituting the parameter require running the fme workbench from within a python script?
Gary
  • Apr 11, 2014 7:00 AM UTC
you cannot do this from a startup script, but you can use a scripted Python parameter instead, it'll accomplish the same thing. You can then link this parameter to the reader WHERE-clause:
I also corrected your code slightly:
datestring = "Edit_date = date '" + date_format + "'"
return(datestring)
Good luck!
David
  • Apr 11, 2014 2:13 PM UTC
David,
Perfect - works like a charm!  Thanks for your help.
Gary
arnold_bijlsma
Forum|alt.badge.img+16
For anyone (like me) who needs an answer to the original question and following @david_r's response, the correct syntax for the WHERE clause for a File GDB is:
"STATE_NAME" = 'California'
Note the double and single quotes
Or in case of a User Parameter called @(StateName):
"STATE_NAME" = '@(StateName)'
For further info, see ArcGIS Help
