Copied & renamed PostGres writer feature types are not written to
  • Jul 4, 2018 9:49 AM UTC
  • 171 views
ngoorman
Forum|alt.badge.img+3
I've been processing data and writing outputs to PostGres tables that are created by the writer. I've created a number of writer feature type by copying an existing feature type and renaming them. Every writer feature type has a unique name, followed by a parameter indicating the year. However, this seems to cause an issue where FME considers the copied + renamed feature type to be the same as the original on some level, and refuses to write to it.
FME 2017.1 (build 17539) gives a somewhat vague warning about feature types but continues processing:
2018-07-04 10:42:52| 102.1|  0.0|WARN  |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2018-07-04 10:42:52| 102.1|  0.0|WARN  |      Features not written - verify feature type fanout/dynamic settings
2018-07-04 10:42:52| 102.1|  0.0|WARN  |  (Check that fanout/dynamic feature type attribute exists and has a value)
2018-07-04 10:42:52| 102.1|  0.0|WARN  |        75173
2018-07-04 10:42:52| 102.1|  0.0|WARN  |==============================================================================
2018-07-04 10:42:52| 102.1|  0.0|WARN  |Total features not written                                               75173
FME 2018.1 beta (build 18482) gives an actual error message and halts translation:
2018-07-04 10:01:39|  12.5|  0.0|ERROR |Cannot have multiple factories with the same name.  Multiple factories were assigned the name 'y__Year__Export.OCHeader_2017_POSTGRES_1_Prepper'
2018-07-04 10:01:39|  12.5|  0.0|INFORM|Translation FAILED with 1 error(s) and 0 warning(s) (0 feature(s) output)
2018-07-04 10:01:39|  12.5|  0.0|INFORM|FME Session Duration: 15.6 seconds. (CPU: 4.3s user, 6.3s system)
2018-07-04 10:01:39|  12.5|  0.0|INFORM|END - ProcessID: 9764, peak process memory usage: 326676 kB, current process memory usage: 326676 kB
Program Terminating
Translation FAILED.
Writing to PostGres and redirecting to Inspector give the same results (the data doesn't show in Inspector either).
I'm assuming I can probably fix this by creating new feature types from scratch instead but thought this was worth pointing out as a potential bug.
UPDATE: I opened the workbench in NotePad++ and searched for the factory named "y__Year__Export.OCHeader_2017_POSTGRES_1_Prepper". This turned out to be an Inspector. Deleted all inspectors from the workbench and now 2018 behaves the same as 2017.
I've also recreated the feature types for the missing tables. Unfortunately this did not solve the issue; if anyone has any bright ideas (or regular ideas) they're appreciated.
UPDATE2: This is odd. In the Navigation pane, when I open the Postgres writer and look at its feature types, only 9 are listed - the ones that are writing successfully. The others are not listed here - even though their properties show that they belong to this writer. Are these orphaned feature types?
UPDATE3: added the workspace below - created in FME2017 (the 2012 in the filename refers to a batch of data). Note that you won't be able to run the workspace as is because of the database connections.
@ngoorman are you able to attach your workspace?
ngoorman
  • Jul 9, 2018 4:08 PM UTC
Hi @MarkAtSafe
Just updated the question to attach the workspace.
ngoorman
  • Jul 26, 2018 12:23 PM UTC
Hi @MarkAtSafe, have you been able to take a look at this workspace? I've tested a bit more myself. It seems that whenever I add another feature type with the same table qualifier "y$(Year)_Export", another feature type with this table qualifier is removed from the Postgres writer's list of feature types. This happens when 8 of these feature types are present. It's still possible to add feature types that do not have this table qualifier. I strongly suspect a bug.
edit: I made a second writer as a workaround but it happens there as well - so it may not be related to the number of feature types already present within the writer
@ngoorman We have had a look at your workspace and have reproduced the problem. It will take some time to fix. The workaround is to not copy the feature type when you have the table qualifier set as a parameter. Either create the feature types from scratch or, copy them before setting the parameter in tale qualifier field.
