Converting MS Excel to Google Maps KML
seanob
Participant
I'm new to FME. I have an Excel spreadsheet with X/Y co-ordinates that I want to convert to KML for use in Google Maps. I've managed to do the conversion OK and create the KML but Google Maps won't read it. Google Earth will read the KML OK but I need to display it in Google Maps.
Any help would be much appreciated.
SeanOB
  • May 3, 2013
try to paste your KML into this web application:
http://display-kml.appspot.com/
Does that work? If not, tell us what happens and any error messages.
Also, take a look at this article from Google.
David
fmelizard
Forum|alt.badge.img+19
  • May 3, 2013
How about writing with the google fusion table writer, to display in google maps? from there you can also export the features as KML.
Hope this helps.
seanob
Participant
  • Participant
  • May 3, 2013
The KML displays fine when copied in to http://display-kml.appspot.com/ but when I try to load it into Google Maps it fails.
Sean
Forum|alt.badge.img+39
  • May 3, 2013
I wonder if something has changed recently within the Import feature on Google maps.
I've just tried to import a file created with fme that I know has worked previously and get an error message.
fmelizard
  • May 3, 2013
Are you udsing FME FME 2013? there have been some changes to the API
sigtill
Forum|alt.badge.img+24
  • May 6, 2013
See this article regarding the API change that occured earlier this year:
http://fmepedia.safe.com/AnswersQuestionDetail?id=906a0000000cgzqAAA
