Converting GEOTIFF with palette to GEOTIFF b/w
  • April 26, 2017
  • 10 replies
  • 105 views
hordor
I need to convert 1 Channel, 1 Palette GEOTIFFs to GEOTIFFS with only 1bit (true b/w). So far I managed to split an incoming GEOTIFF-feature into several new GEOTIFF-features (one new feature for each used color in the palette). Afterwords I change them to black and white by using the expression evaluator. Despite the fact that only two colors are used it is technically a 3 channel 8-bit/channel Geotiff right now. By using a RasterSelector and the RasterPaletteGenerator I convert this to a 1 channel 1 Palette Geotiff, where the palette only has two used entries.
However I found no way to save it as a true (1bit) bitmap with the GEOTIFF-Writer.
Any ideas out there?
Uwe
itay
Forum|alt.badge.img+18
  • April 26, 2017
Hi @hordor,
Could it be that you need to coerce it into a different interpretation type ? try the RasterInterpretationCoercer before writing.
Hope this helps.
  • April 26, 2017
Hi @hordor, try setting 1 to the Number of Bits per Cell parameter in the GoeTIFF writer feature type.
hordor
  • April 26, 2017
Hi thanks for the hints. Using the RasterInterpretationCoercer allows to convert to Grayscale 8bit. Theres for bad luck no setting "bitmap". Setting the "Number of Bits per Cell" seems no to work at all. In the screenshot u can see the result using Number of bits per Cell after converting to Grayscale. Theres still "original color" - in German Originalfarben - 16,7 Million. Any ideas whats wrong?
  • April 26, 2017
Your screenshot seems to show that the original colors is equal to 2 (1bits per pixel) ?
hordor
  • April 26, 2017
It is possible to convert it with e. g. Irfan View afterwords. This can be done in batch so there is at least a solution for that. However, as the logic is already done with FME and it is only a problem of saving in the right format it would be much better doing it all the way in FME.
hordor
  • April 26, 2017
This is what is should look like after saving as true bitmap...
  • April 27, 2017
In my testing, the Current colors (Aktuelle Farben) property seems to become 2 if you set BIP to the Interleaving Type parameter in the GEOTIFF writer feature type.
itay
  • April 27, 2017
You can always call ifranview from within FME via the systemcaller transformer.
hordor
  • April 27, 2017
I finally made it with the systemcaller. The code in systemcaller is:
" "C:\\Program Files (x86)\\IrfanView\\i_view32.exe" "K:\\TK25 bw\\tmp\\*.tif" /bpp=1 /convert="K:\\TK25 bw\\import\\*.tif" "
Thanks for your help.
hordor
  • April 27, 2017
Bad Luck it is not working that way on my system. However the solution with systemcaller works perfectly. Thanks for your hepl.
