Converting character encoding before reading text files
  • Nov 30, 2020 9:13 AM UTC
  • 13 replies
  • 1893 views
peteralstorp
Forum|alt.badge.img+8
Hi, Safers!
I read Text Files as Whole text at once but I need convert files not in UTF-8 to UTF-8 before reading. This is because FME needs to know the encoding when it reads the file.
I figure one easy way to do this is to store the files to a temp folder and via the SystemCaller run some windows command to convert the files not already in UTF-8 (this can be more than thousands of files so preferably I can convert only the files that needs converting) before reading them with the Text File reader with Character Encoding set to UTF-8.
Does anyone have any suggestions on how to solve this in an easy way? Preferably within the FME script if possible...
Kind regards, Peter
Best answer by david_r
No, I have to check for each file.
If you can use Python, this may be a viable option, which could potentially save you a lot of guesswork: https://pypi.org/project/chardet/
You will notice that even this library can only detect the encoding with a certain confidence.
  • Nov 30, 2020 9:20 AM UTC
Have you tried using the AttributeEncoder? It can convert between different encodings, including utf-8.
Forum|alt.badge.img+54
  • Nov 30, 2020 9:21 AM UTC
Do you already know what encoding the files have which are not UTF-8?
peteralstorp
  • Nov 30, 2020 9:23 AM UTC
I have to set the encoding when reading the file so this problem has to be solved before reading the file, no?
peteralstorp
  • Nov 30, 2020 9:24 AM UTC
  • Nov 30, 2020 9:27 AM UTC
So how are you determining the encoding you need to read from? Most programs that show you an encoding of a text file are a best guess not an absolute.
peteralstorp
  • Nov 30, 2020 9:30 AM UTC
Ok, I didn't know that. I open the file in Notepad++ now and check the encoding there. When it comes to this problem I wish I lived in an English speaking country and not Sweden...
The reader encoding only tells FME what to expect so that it can correctly encode the attributes for you, but you can override it in the AttributeEncoder. Of course, if you know the input encoding then that will simplify the tast quite a bit.
Worst case, there is also the "Data File" reader which lets you read the binary contents of the file.
  • Nov 30, 2020 9:31 AM UTC
No BOM in the utf-8 files? It might be worth checking, as it would make it easier for you.
  • Nov 30, 2020 9:32 AM UTC
Encoding issues are the bane of my life at the moment, living in the UK isn't helping!
peteralstorp
  • Nov 30, 2020 9:36 AM UTC
The files in my case can be created in any text editor or other programs so I can never know what to expect. Somehow I need to check.
peteralstorp
  • Nov 30, 2020 9:38 AM UTC
Haha, really! Yeah, there are probably many of us who would like to see a well thought out handling of this problem within FME.
  • Nov 30, 2020 9:46 AM UTC
peteralstorp
  • Dec 9, 2020 8:48 AM UTC
Thanks, @david_r​ , I was hoping for a simpler answer, but don't we always? I'll look into your proposed Python-solution!
