Converting AGS Files as a GIS Layer
  • July 21, 2020
  • 178 views
Hi all,
Just been on working on converting AGS Files to GIS format.
This is the first time I have gone through this and it is a difficult file to convert.
Just wondered if anyone has any experience with this and are there any steps that have to be done before using FME to convert.
@daveatsafe - I have seen a similar thread where you have done some fantastic work building the AGS FME file. I have played around with it but struggle with the output.
Below is the FME file:
I have also used the AGS transformer which FME now has but not getting the output I was after.
@cardiofaz Can you give an example of the result your expecting and what you're getting from FME, perhaps include a small sample dataset. The Idea I think your referring too is: Adding support for AGS format . You can also download and edit the custom transformer to tune it to your data if needed.
