Convert XML to csv preserving the Structure
danilo_fme
Forum|alt.badge.img+41
I would like to Read a XML and convert to csv file, but preserving the sequence of Attributes from XML.
The Structure XML:
When I create a just workspace Reader ( XML ) to Writer ( CSV ) respecting Dynamic Schema, the Attributes are'nt in order.
Thanks,
Danilo
Best answer by danilo_fme
Hi people,
I found a resolution.
danilo_fme
  • January 5, 2018
Hi people,
nathanatsafe
Forum|alt.badge.img+7
danilo_fme wrote:
Hi people,
Hi @danilo_fme. That's great! I spent some time looking at this and couldn't figure it out. I'm pretty new to XML manipulation. Would you mind sharing what your solution was?
Thanks,
Nathan
johnmarcdechaud
danilo_fme wrote:
Hi people,
Hello I have the same issue can u show us you solution please?
