Convert osm shapefiles to 3d
  • November 25, 2015
  • 51 views
how to transform osm shapefiles to 3d cityGML or CAD files
Best answer by davideagle
Your question is a little brief but one option you have is that you can drape your data over a digital surface model (DSM) to extract heights. In the past when I have done this I have draped the features that I have wanted to add heights to over a DSM and then taken an average of heights extracted for the (in my case) Building and then used the 3DForcer to create 3D buildings.
davideagle
Forum|alt.badge.img+21
  • December 7, 2015
  • December 8, 2015
You can also try the Extruder transformer to convert the building footprint from 2D to 3D, once you've got the Z values as 1spatialdave described. Have a look at the KnowledgeBase article on extruding building outlines . There's also a tutorial on 3D modeling in FME.
