Convert nested complex GeoJSON to SQL Table
  • Mar 12, 2018 7:12 PM UTC
  • 66 views
Hi All,
I am trying to convert nested geoJSON to SQL table but FME converter is missing out on few tags when converting to a sql table (). The geoJSON file is attached below for reference. the FME SQL writer is not able to read "geometry" tag at line 75 from geoJSON file ().
Thanks
  • Mar 12, 2018 11:25 PM UTC
Hi @abhaga, the missing fields seem to correspond to list attributes which have been converted from arrays in the source GeoJSON document. A list attribute could contain multiple values as its elements, whereas each field in the destination table can only contain a single value, so FME won't map a list attribute to a field automatically. See here to learn more about list attribute: About List Attributes
The solution depends on how you need to write the list elements into the destination table.
For example, the "wof:belongsto" array in the GeoJSON example contains six elements (102191575, 85633793, 85977539, etc.). How do you want to write them into the destination table?
