Convert .las to .dwg or .dxf ?
  • Jun 16, 2016 11:52 PM UTC
  • 2837 views
Hello, i am recently started using this software and i want to convert to classes from my las file to dwg so i can use them in Skatch up? Is there a way or i am too newbee :D Thanks
Best answer by redgeographics
Short answer: yes. You can read the .las file using the LAS reader, then use a PointCloudCoercer to turn the point cloud into individual points and output those to DWG/DXF (or to Sketchup directly, FME supports that too).
Alternatively you can use a SurfaceModeller to generate a TIN or a surface from the point cloud data and export that. That might actually be a better solution because point clouds tend to have lots of points and it may be way too detailed for what you want to do.
Forum|alt.badge.img+63
  • Jun 17, 2016 10:21 AM UTC
@redgeographics Thanks Man. That does not sound complicated and will save me some time if i manage to make that model :D
  • Jun 17, 2016 11:33 AM UTC
I made it, it was not that hard, i am new but thanks again.
