convert kmz to tab
  • Sep 13, 2017 12:37 AM UTC
  • 5 replies
  • 136 views
Is there a way to convert a KMZ file that contains a description field to tab format, where the description field becomes a field in the tab file? I have tested readers and writers for KMZ to KML and kml to tab and Vertex creator (it would be good to have the lat/long fields listed too) and none of this quite works.
Best answer by danilo_fme
hi @sladlow, if tou want to extract attributes from kml you can check this link https://knowledge.safe.com/articles/19918/how-to-expose-feature-attributes-from-kml-tag.html
Thanks
mygis
Forum|alt.badge.img+14
  • Sep 13, 2017 12:40 AM UTC
You should be able to do that @sladlow please share you kmz file so we can guide you better.
danilo_fme
Forum|alt.badge.img+58
  • Sep 13, 2017 1:40 AM UTC
Thanks
  • Sep 13, 2017 1:54 AM UTC
Thanks
Thanks. I followed this workspace exactly and it didn't work - the description field arrived as part of the xquery expression.
I can't do that sorry. I thought that there would be a relatively straight forward way to do this that didn't actually require a specific dataset?
  • Sep 13, 2017 4:53 AM UTC
Thanks this worked! I just needed to go in and add the description field. It wouldn't copy over the lat/longs but I added these in MapInfo.
