convert dwg to kml
How to convert dwg files to kml.
Tried to convert get
Total Features Written 0
KML: Writing dataset to filesystem...
KML: Feature does not have a coordinate system specified
Storing feature(s) to FME feature store file `.\\mapping_log.ffs'
  • March 5, 2016
Hi @fiber, the KML writer requires that input features have a coordinate system definition, and the error says that a feature doesn't have that. Try setting appropriate coordinate system to every feature. You can use the CoordinateSystemSetter transformer to do that.
mygis
Forum|alt.badge.img+13
  • March 7, 2016
Hi Fiber,
Not sure what coordinate systems you are using on the CAD file. Let's assume it is properly geo-referenced you need to convert your data to WGS84 to be able o write into KML, the coordinate system used is LL84 . This should help.
