Connecting to mysql
  • Nov 20, 2013 10:06 AM UTC
  • 58 views
Forum|alt.badge.img+54
Has anyone managed to successfully connect to a MySQL database using the MariaDB reader?
The first time I tried I successfully got the table list and was able to choose a table but when it came to add the reader it just said "Running indefinitely" until I cancelled it.
Now if I try to add it again I get a fatal error and FME shuts down
(FME 2013 SP3 Build 13528)
  • Nov 20, 2013 10:16 AM UTC
Have you tried the troubleshooting steps?
David
  • Nov 20, 2013 10:30 AM UTC
All of the fme docs pages hang my browser (different machine to the one running FME) but from what I could read there doesn't seem anything else to try.
It returns all the tables in the database I'm connecting to so I'm assuming all the parameters are correct. I would expect an error in the setup to produce a different error to "FME EXE has enountered a problem and needs to close"?
we recognized a similar problem. In our case an update of the operating system from WinXP to Win7 helped. Maybe you can test this...
Best regards,
Stefan
