Hi!
I have a background map on DWG + a set of data. My workbench look for an error on the set and if it found it, a buffer is output.
I would like to export the backgroud only when an error is found. Is it possible?
Thanks!
Hi!
Thanks!
Best answer by ebygomm
It should be possible, how best to achieve it probably depends on your workflow. If you can post your workflow or a screenshot people can probably advise better.
One way might be to use a featuremerger, send the error (use a sampler if more than one error) to the supplier, send your background map to the requester, join on the value1, then link only the merged port up to your writer. If there is no error, nothing exits the merged port
