Conditionally join tables
  • Jul 25, 2019 1:56 PM UTC
  • 165 views
i have two tables, one containing a code list and the meaning of each code:
Code
Meaning
500
Grass
501
Tree
502
Street
The other table, coming from the land survey team, contains the coordinates and the code of the point.
X
Y
Code
51XXXXX1
9XXXXXXX1
501
51XXXXX2
9XXXXXXX2
500
51XXXXX3
9XXXXXXX3
500
I want the meaning of each code in this table is added in a new column:
X
Y
Code
Meaning
51XXXXX1
9XXXXXXX1
501
Tree
51XXXXX2
9XXXXXXX2
500
Grass
51XXXXX3
9XXXXXXX3
500
Grass
I m new to FME, usually i would do this with a script, e.g. in QGIS. My FeatureMerge options so far look like:
Any hints are welcome!
Thank you!
danilo_fme
Forum|alt.badge.img+58
  • Jul 25, 2019 3:14 PM UTC
Hi @meyerlor
I used this configuration on transformer FeatureMerger:
The result:
Thanks,
Danilo
erik_jan
Forum|alt.badge.img+26
  • Jul 25, 2019 3:39 PM UTC
For FME 2018 and newer, you can use the FeatureJoiner instead of the FeatureMerger.
The FeatureJoiner is faster and more intuitive to use.
If both tables are in a database, I would use the SQLCreator and have the database execute the join.
The SQL would look something like:
Select survey.*, lookup.meaning
from survey, lookup
where survey.code = lookup.code;
Hope this helps.
