Concatenating Published Parameters
  • September 21, 2017
  • 41 views
Hello folks,
Simply, what I am trying to do with my script, is create a service that allows the person running my process on FME Server to add a Plan ID # to the start of a file deliverable name. Example:
Current output file name: Complete_Data_DWG.dwg
Published Parameter "PLAN_ID" value: 24883
Desired output file name: 24883_Complete_Data_DWG.dwg
I have already tried using "$(PLAN_ID)_Complete_Data_DWG.dwg" but it only returns that exact string (with $(PLAN_ID) and not the user set value).
Basically my script works and I am just trying to make it more aesthetically pleasing and to also provide better file management for my clients.
Thank you for your time,
Moe
Try using FME_MacroValues:
FME_MacroValues["PLAN_ID"]_Complete_Data_DWG.dwg
erik_jan
Forum|alt.badge.img+19
If the file name is also a published parameter, it might get evaluated before the PLAN_ID parameter.
If you do not need the file name to be published, convert it into a private parameter (right click menu on the parameter) and it will get evaluated after the PLAN_ID and should get the right value.
Hi @moe
would you mind sharing your workspace? Or maybe, could you please post a screenshot that shows how you concatenate the new file name and where the name is used?
