Combine multipe excel files with multiple sheets into one workbook.
  • June 9, 2016
  • 138 views
I have a folder that contains all the excel files I need to parse. I need a way to combine all the workbook files and work sheets and parse the data into a new workbook in a table format. Can FME do this?
erik_jan
Forum|alt.badge.img+18
  • June 9, 2016
If all the worksheet in the source files have the same attribute columns, you can read all files by selecting them as the source of the reader (or use *.xls) as a source and you will need to merge the sheets by using the option: single merge feature type as shown in image below:
Then write to an Excel writer with one feature type.
