Combine multipe excel files with multiple sheets into one workbook.
  • Jun 9, 2016 8:13 PM UTC
  • 215 views
I have a folder that contains all the excel files I need to parse. I need a way to combine all the workbook files and work sheets and parse the data into a new workbook in a table format. Can FME do this?
erik_jan
Forum|alt.badge.img+26
  • Jun 9, 2016 9:57 PM UTC
If all the worksheet in the source files have the same attribute columns, you can read all files by selecting them as the source of the reader (or use *.xls) as a source and you will need to merge the sheets by using the option: single merge feature type as shown in image below:
Then write to an Excel writer with one feature type.
