Combine binary pdf files?
  • Sep 27, 2018 1:59 PM UTC
  • 113 views
johnglick
Forum|alt.badge.img+7
I'm receiving binary pdf files from a web service. I've successfully decoded and written them to my file system. However, I would like to combine certain files with a similar attribute into one pdf of multiple pages. Any ideas how I can do this in fme?
lottegis
  • Sep 27, 2018 8:22 PM UTC
I'm thinking you may be able to do this by command line with SystemCaller but I don't think Acrobat supports this operation by command line. Here's an elaborate solution someone undertook where you can write a simpler batch file: https://superuser.com/a/527079
johnglick
  • Oct 1, 2018 5:42 PM UTC
I ended up setting this pdf combining requirement with a webservice called convertapi.com. Slows the workspace down a bit, but it works.
