My workflow reads an SDE, carries out some transformations, and then writes to .xlsx using a feature writer and a template file. When I open the excel file and sort columns the sort function works the first few times but then it begins to only sort certain columns leading to mismatched data in the document. There doesn't seem to be any pattern as to which rows sort and which don't. Sometimes it is only the ObjectID column which will sort.
