Column names on Oracle VIEW doesn't show on FME workbench.
  • Sep 25, 2024 2:49 PM UTC
  • 85 views
pushpa
Forum|alt.badge.img+9
Hi there,
I have placed few VIEWS on Oracle Database changing TABLE column names.
ie: ID as PLANT_ITEM_ID
When I connect the VIEW via FME 2023.2.1.0 all column names are showing as what is recorded on Oracle Tables. It is ignoring column names I have set up on VIEWs. How do I get around this issue?
I don’t want to use “attribute manager” to change the names. I have already done that on my VIEWs.
Is there a way I can see the Column names on VIEWS through FME?
thanks
Regards,
Pushpa
kailinatsafe
Forum|alt.badge.img+24
Hello @pushpa, are you able to specify the oracle reader in use, as well as the build of FME Form being used? I created a new view, edited a column name to include ‘_X’ and saw this reflected in FME Form 2023.2.1 build 23774 & 2024.1. I might be interpreting incorrectly, are you able to share a screenshot of the view columns and the columns shown on the reader feature type in FME Form? Best, Kailin.
