Clip LAS at Feature Reader?
  • January 13, 2017
  • 54 views
Is there some way I can make use of the featurereader to clip LAS files with the initiator?
  • January 13, 2017
Hi @giskis, I don't think there is any way to clip a point cloud with the FeatureReader. Consider using the Clipper transformer after reading the LAS dataset.
itay
Forum|alt.badge.img+18
  • January 13, 2017
Yes, you can create an object via the Creator (think of a bounding box) and use it as an initiator, just make sure you set the Spatial Filter correctly (intersect).
Hope this helps.
  • January 13, 2017
Hope this helps.
Unfortunately this is not the case, problably since its considered as one feature
  • January 13, 2017
Ok, thanks! Its to bad because the functionality is there when using a real reader in the parameter "Search Envelope"..
