Civil3d - Surfaces
  • Apr 5, 2013 9:23 AM UTC
  • 5 replies
  • 332 views
sigtill
Forum|alt.badge.img+25
I have read http://fmepedia.safe.com/articles/FAQ/Autodesk-AutoCAD-Civil-3D and wonder how you are handling surfaces. Inputdata is a Surface/TIN and I also want to write to a Surface/TIN in DWG-format.
Can you read the Surface in Civil3D as as "triangles" , then aggregate these within FME and write them out as Surface?
I would really love for FME to be able to read Civil3D surfaces. If you export a surface in Civil3d as a LandXML, FME will read the surface with the XML reader, but wont have the correct outer boundary. If I extract the outer boundary of the surface in Civil3d then I can clip the surface triangles using this boundary. This is too much pre-processing and you would have to export a new XML file and boundary every time you update the surface. I would love to be able to use FME to read a Civil3D surface directly from the dwg file with the correct outer boundary. I haven't tried writing the surface back out to a dwg, I would mostly use this for CAD to GIS purposes.
Forum|alt.badge.img+5
I believe yes, you can create triangles and a 3d boundary using Civil3D and then read them into FME and recreate as a surface. Then you can write it out as a surface to DWG.
It makes me wonder why we can't read a Civil3D surface, but can read/write them in plain DWG. I suppose there must be something special about Civil3D entities that we don't yet support.
kelvin.jenkins
Any updates on this question from 2013?
Still would be good to be able to read a surface directly from a Civil3D DWG
danminneyatsaf
Forum|alt.badge.img+13
Hi @kelvin.jenkins​,
Surfaces can be read with the Civil3D Reader in current versions of FME. You can find more information on geometry types supported by the Civil3D Reader here: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/civil3d/quick_facts_civil3d.htm
kelvin.jenkins
Great thanks
