Civil 3D Reader - property sets - fatal error
  • December 10, 2019
  • 7 replies
  • 40 views
jasperwis
Forum|alt.badge.img+15
I want to access the property sets a of a dwg in FME.
I enabled the 'Civil 3D and CAD Entities' option in the Schema Mode of the Civil 3D Reader.
When i attach an inspector to the reader, I get a fatal error.
AutoCAD Reader: An error occurred for dataset 'C:\\Users\\wisbeja\\Documents\\AWV\\FME voor dataconversie DAVIE\\voorbeeld data\\DWG solid and prop set\\small_test.dwg', in function AutoCAD2004Reader::read. Exception thrown: 'Invalid ResBuf' (Invalid ResBuf)
dwg file is attached.
When I read the dwg with a dxf/dwg reader the inspector works. But I guess I am not able to access the property sets with this reader.
Any suggestions?
Jasper
Best answer by chrisatsafe
Hi @jasperwis and @becchr,
Just wanted to let you know that the fix for this issue has now been released in the latest official release of FME (build 19822+). Please not that this fix has also been implemented in the latest beta (build 20174+) as well.
You can get the installer for the latest official release and beta at: https://www.safe.com/downloads
Thank you again for reporting this and for your patience while our team worked to resolve this issue!
jasperwis
  • December 17, 2019
Anybody knows how to solve this Invalid ResBuf issue?
jasperwis
  • December 23, 2019
FME can't handle properties of type List (choose value from a drop down list).
After removing all properties with type = List in the property set definition, FME was able to read the file.
Unfortunately, for my case, these are very interesting properties.
becchr
Forum|alt.badge.img+26
  • December 23, 2019
hi @jasperwis, thank you for sharing, that's a bummer indeed...
chrisatsafe
  • December 27, 2019
Thanks for reporting this @jasperwis, we are currently looking into this issue and tracking it in our system as: FMEENGINE-62576 - @becchr if you would like to be notified by email when this is resolved, please submit a case via the report a problem web form and reference the issue number mentioned above.
chrisatsafe
  • February 5, 2020
jasperwis
  • February 7, 2020
Great news.
Works perfectly in 2019.2 latest release. Properties with values from choice lists are read correctly.
Not working in 2020 beta. Instant crash when adding a C3D DWG reader.
Looking forward to a fix for the other related issue, about C3D properties based on formulas that are not being read.
jovitaatsafe
Forum|alt.badge.img+11
jasperwis wrote:
Great news.
Hi @jasperwis,
Would you be able to share the Windows Crash Event from the Event Viewer, under Windows Logs > Applications? It'd be helpful to see what the faulting dll is and what's crashing. I'll give it a try on my end and let you know if I can reproduce the crash for the 2020 beta, thanks for letting us know!
**Update: I checked in with our development team and they think it's related to a known issue that relates to the Civil3D format (FMEENGINE-62938) that's in the works and nearly ready to be released. Please look out for FME 2020 build 20177+ and give it a try when it's available to see if that resolves the issue for you and let us know here. Thanks!
