Choosing parameter value from a list stored in an Excel field,
  • Oct 7, 2014 12:37 PM UTC
  • 48 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out how the a parameter value can be selected from a list saved in an Excel table
For example, in the screenshot below, I wanted to choose the “PlanType” value from the shown Excel table
How this might be accomplished?
Thank you
Best
Jamal
Best answer by takashi
Hi Jamal,
If you choose "Choice" as the parameter type, you can import the Excel list to its choices. Note that the configuration is static. After you once imported, the configuration will not be changed even if you change the original Excel list. You should import again or edit directly, if necessary.
Takashi
  • Oct 7, 2014 2:09 PM UTC
Hi Jamal,
Takashi
jamal
  • Oct 7, 2014 3:30 PM UTC
Perfect. Many thanks Takashi for the help.
I would prefer it to be dynamic such that if any change occur in the excel, it will be reflected on the list.
However, it is great now. I can live with it
Best
Jamal
