Checking ACAD layer with Excel list
  • Mar 7, 2018 2:42 PM UTC
  • 80 views
I'm new at FME so I'm asking for some help. I have autocad layers that contain a three letter code (ex: <Project>-<Beginning>-<End>-<CODE>-...) and I have an Excel sheet that contains a list of Codes.
I'd like to check if the code in the cad layer exists in the excel list. Then fill a report (excel) with a new feature called "CodeCheck" and the value would be Y or N.
I'm using an attributeSplitter to get the code but I can't find a way to check if the code is in my excel file. I must get the matched AND unmatched in my output (only the cad layers).
I tried Testers, filters, change detector,... but nothing end up like I want.
Please, how do I check the code and fill my report ?
Louis.
gio
Forum|alt.badge.img+15
  • Mar 7, 2018 5:33 PM UTC
@louis_c3
You can merge the excel records unconditionally and then use a tester.
Unconditional merging:
FeatureMerger 1=1, proces duplicates, set a list name. After that use listexploder on the list.
You can also use a Inline Querier to do this. SQL for this is not difficult.
gio
  • Mar 7, 2018 5:35 PM UTC
@louis_c3
Another method would be to use a feature reader on the excel with a select statement.
  • Mar 8, 2018 8:30 AM UTC
Thanks @gio ! FeatureMerger is the tool I was looking for ;)
