Change output excel sheet (or file name) based on attribute name
  • Nov 27, 2018 6:41 PM UTC
  • 7 replies
  • 387 views
majkiboy
I'm sorry if this has been answered before but I couldn't find the exact answer to my question which is:
How do I change the output name of an excel sheet (or file) based on a specific attribute name.
Example:
I need my output sheet name to be "Namn" and automatically read from the attribute name since I have multiple similar datasets but with variations on "Namn". All of which should be put into a separeate sheet but in the same file.
It is probably really simple but as I said, I couldn't find it.
(For me the output parameters and schemas are real confusing)
Best answer by debbiatsafe
I'm not sure it helps. The first sentence in the link you sent says: "A fanout is a way within FME to split output data based upon the value of an attribute. " I don't need the value of the attribute, I need the name. Or am I missing something obvious?
I need something simple like "@column_1_attribute_name" to put into the "sheet name" box. Is there something like this?
Hi @majkiboy
My apologies for misreading your question.
Attached is a workspace which uses the Schema reader to get the attribute names of the input Excel file, Tester to get the first attribute name, and a FeatureJoiner to join the attribute name onto the input Excel features.
I hope this helps.
GetAttributeName_QA.fmwt
debbiatsafe
Forum|alt.badge.img+24
Hi @majkiboy
You would want to use a feature type fanout. You can set this in the Excel writer feature type dialog. This article also contains instructions on how to fanout in FME.
I hope this helps.
Forum|alt.badge.img+54
  • Nov 27, 2018 7:01 PM UTC
Hi @majkiboy
I hope this helps.
I think they want the sheet name to be called Namn (or the other variations of this), rather than the value of Namn.
majkiboy
  • Nov 27, 2018 7:08 PM UTC
Hi @majkiboy
I hope this helps.
  • Nov 27, 2018 7:09 PM UTC
Is it always the first column?
majkiboy
  • Nov 27, 2018 7:15 PM UTC
Yes, it is!
debbiatsafe
  • Nov 28, 2018 9:14 PM UTC
Hi @majkiboy
I hope this helps.
majkiboy
  • Dec 4, 2018 1:50 PM UTC
Hi @majkiboy
I hope this helps.
Thank you very much! I still kind of don't understand this, but at least I can see it working. I have to study what you actually did in your workspace!
