center and zoom (set scale) to polygon within google static maps
  • Jun 13, 2018 7:23 PM UTC
  • 165 views
apence231
Forum|alt.badge.img+10
My workflow right now is set up to do some calculations on a property boundary then be able to show that property on an aerial image. Where I'm getting stuck is to be able to find a way to set the scale (zoom level) of the google static map so the polygon is centered and at an appropriate zoom level.
I'm using the 'google static map fetcher' transformer and have everything working to be able to center the polygon within the google map, just want to find a way to set a scale level to have it adjust to the different size polygons.
Best answer by debbiatsafe
Hi @apence23
Perhaps using the StaticMapOverlayer would work for your situation? The output from the Tiles port should be the static map feature.
debbiatsafe
Forum|alt.badge.img+24
  • Jun 19, 2018 4:56 PM UTC
Hi @apence23
apence231
  • Jun 20, 2018 5:20 PM UTC
Hi @apence23
that works like a charm! I just had to update some of the transformers to newer versions but that will work. thanks for the heads up on this one, should have kept looking through the FME Hub
