CAT Files and column definition
  • May 30, 2018 8:15 AM UTC
  • 8 replies
  • 184 views
Hi there,
I've started to play around with the CAT (column aligned text) reader. Is there a way to specify column definition using another text or csv file instead of hardcoding it in the reader?
Any advice would be good.
Thanks,
W
You can't dynamically set the column widths on the CAT reader. I think the best FME can offer is the TextLine Reader followed by the AttributeSplitter. To make that 'dynamic' you could try using a scripted parameter to set the AttributeSplitter's format string.
danilo_fme
Forum|alt.badge.img+58
  • May 30, 2018 12:33 PM UTC
Excellent @MarkAtSafe
fmelizard
Forum|alt.badge.img+22
  • May 31, 2018 5:26 PM UTC
Hi @generationn00b Can you please post a suggestion at https://knowledge.safe.com/content/idea/list.html about setting the CAT reader's schema with another file? I've seen this idea before.
Posted. See
https://knowledge.safe.com/idea/71574/dynamically-set-the-column-definition-for-column-a.html?
Thanks. I ended up using Pythoncreator but might investigate using scripted params as well..
  • Jun 2, 2018 3:55 PM UTC
A possible workaround (or a hack ?) in the current version of FME is: use a FeatureReader to read a CAT file and create a published parameter linking to the schema parameter in the FeatureReader (CAT reader).
Then, you can set a schema through the published parameter with this syntax.
<field name>,<field type>,<column width>[,<field name>,<field type>,<column width>]*
e.g.
field1,Integer,5,field2,String,20,field3,String,15
See the parameters dialog of the CAT reader to learn possible field types.
Also you can run the workspace through a WorkspaceRunner within another workspace. In the case, you can set the schema through a feature attribute.
e.g.
Just tested this with FME 2018 and it works like a charm.  Thank you!!
bo
Forum|alt.badge.img+10
  • Nov 20, 2018 4:35 AM UTC
e.g.
@generationn00b, @takashi, we are looking to use the same pattern to load CAT datasets.  Your post was very helpful; however, I still could not figure out how and where to "set the schema via parameters".  Do you mind providing a bit more detail or maybe a screenshot?  Thanks!
