Can't read files in folders with brackets with Directory and File Pathnames reader.
  • Nov 9, 2016 9:55 AM UTC
  • 5 replies
  • 340 views
nielsgerrits
Forum|alt.badge.img+67
Dear community,
When I try to scan a directory where the folder contains brackets the files in this folder are not being read.
I can imagine why brackets cause problems but sadly this data is often external input. Does a workaround exist? (Other than scanning folders for brackets and edit the folders.)
folder:
output:
path_windows
D:\\tmp\\New folder (25)\\input\\test
D:\\tmp\\New folder (25)\\input\\[test]
D:\\tmp\\New folder (25)\\input\\test\\data.txt
D:\\tmp\\New folder (25)\\input\\test\\[data].txt
missing output:
D:\\tmp\\New folder (25)\\input\\[test]\\data.txt
D:\\tmp\\New folder (25)\\input\\[test]\\[data].txt
Best answer by mark2atsafe
OK, I see an update to our documentation to cover this scenario. It says...
C:[data]Sometimes specifying the glob pattern syntax can conflict with the special characters in the path. In this case, the directory contains [] characters and by default will be misinterpreted as a glob pattern.
This case can be read correctly by removing the default glob pattern ‘*’ and leaving the Path Filter empty. This will disable glob interpretation and the path will be interpreted literally.
I hope that helps. These brackets are a special case because of how they are usually used for a pattern, so I'm hopeful no other special characters should cause similar problems.
itay
Forum|alt.badge.img+19
  • Nov 9, 2016 11:01 AM UTC
Hoi @nielsgerrits I dont think a workaround is possible with the Files and Directory Reader, so some kind of manipulation beforehand of the folder and file names will be probably needed.
Probably a python script can be used for that, but also good old DOS (dir and rename) can be used with the SystemCaller.
Hope this helps
removebracketsfromfoldername.fmw
nielsgerrits
Hope this helps
Nice one, SystemCaller is getting a favorite transformer.
mark2atsafe
Forum|alt.badge.img+59
I can't think of a workaround, but I have filed this issue with our developers as PR#73743
If it's a small fix then maybe we'll be able to get it into FME2017 (no guarantees though)
nielsgerrits
Thanks @Mark2AtSafe, one of the reasons for me to post these isolated reproducers is to give you guys input for making even better software. :-) Wondered if a list of characters causing this problem is available so I could test input folders? I could generate something myself with ascii codes but if available allready...
mark2atsafe
  • Nov 23, 2016 9:36 PM UTC
