Can't read events from Azure EventHubs using AzureEventHubsConnector
  • June 23, 2022
  • 40 views
Hello FME Community
I'm getting following error when trying to read events from Azure EventHubs using AzureEventHubsConnector:
Python Exception <TypeError>: Message data is not compatible with string type'generator' object has no attribute 'decode'
All parameters were set correctly and events are actually passing through other clients.
Thank you in advance!
JennaKAtSafe
Forum|alt.badge.img+7
Hi @siriosus​, hard to tell what the feature/attribute generator and decode means without an example of your workspace. Could you provide some more context on this?
