I get the following error when trying to access a Pervasive SQL database
Starting translation...
FME 2018.0.0.0 (20180308 - Build 18284 - WIN32)
FME Database Edition (node locked-crc)
Temporary License: 16 days left.
Machine host name is: cmcclain
Operating System: Microsoft Windows 10 64-bit (Build 16299)
Copyright (c) 1994 - 2018, Safe Software Inc.
Safe Software Inc.
Creating reader for format: Pervasive PSQL
Trying to find a DYNAMIC plugin for reader named `PERVASIVE'
Loaded module 'PERVASIVE' from file 'C:\\apps\\FME\\plugins/FME_ADO.dll'
FME API version of module 'PERVASIVE' matches current internal version (3.8 20180209)
Pervasive Reader: Read 0 DEF line(s). Found 0 attribute(s)
Pervasive Reader: Opening `mcsdb' for read operation
Pervasive Reader: Connection failed. Connection string `Provider=MSDASQL;DSN=mcsdb'. Provider error `(-2147217843) [PSQL][ODBC Client Interface][LNA][PSQL][SQL Engine][Data Record Manager]Invalid user authorization specification.'
Failed to open reader
Failed to obtain any schemas from reader 'PERVASIVE' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
FME Session Duration: 0.3 seconds. (CPU: 0.1s user, 0.1s system)
END - ProcessID: 5376, peak process memory usage: 40568 kB, current process memory usage: 40528 kB
Program Terminating
Translation FAILED.
Workspace generation failed. Parameter file was C:\\Users\\cmcclain\\AppData\\Local\\Temp\\FME_1522349455173_6808.
