Can published parameters be specified for scheduled jobs on FME Server?
  • Sep 25, 2013 5:34 PM UTC
  • 54 views
I am looking into using FME Server 2013's scheduling capabilities to run workspaces on a schedule. These workspaces have many published parameters that must be specified. Is it possible to use the built-in web interface to schedule jobs and specify the parameters these jobs should run with? I am not seeing anything like that in the UI or documentation.
Best answer by logan_pugh
Never mind, the parameters pop up after selecting a workspace. This is noted in the FME Server documentation here: http://docs.safe.com/fme/html/FME_Server_Documentation/Default.htm#Web_UI/AdminWebHelp/Adding%20a%20Scheduled%20Task.htm
  • Sep 25, 2013 5:46 PM UTC
